Brakes-ebcm,dumpvalve or combination?
I own a 1992 Chevy K1500 350 TBI Z71. My problem is with my brakeing system and was wondering if anyone could help. I noticed that the brake pedal was traveling further than it should and also the brake warning lamp illuminated when i pressed the pedal to the floor and stayed on. The problem got worse to where the pedal went right to the floor but i noticed that with the engine off it would be firm. I have no leaking wheel cylinders, new pads and shoes and so i replaced the master cylinder, bench bled it, bled the system to no avail. I then ran a diagnostic self check on the truck and it came out as a code 3=open dump soilenoid or EBCM malfunction. I went to a junkyard replaced the Dump valve and it still did not work. Went back to junkyard and got an EBCM, nope still not working. What could it be? I thought it may be the master cylinder as i have had remanufactured parts that are bad before so i removed the two lines from the master cylinder and capped them with threaded plastic caps and the pedal was hard suggesting a good master cylinder. The only thing i have not replaced is the combination valve. I dont know if the junkyard parts are bad or not(maybe the reason why the truck was wrecked cos he couldnt stop)but any help would be greatly appreiciated!!
