Old 09-30-2004, 02:11 PM
tomahawk tomahawk is offline
ebrake adjustinments
hey can anyone out there confirm this one for me. i need to adjust the ebrake in my car. i believe i need to do it the part where the single cable fromm inside the car splits into two separate cable that goes to each tire. or do i need to take out the center console and adjust something under there? any help is always appreciated. thanks
Old 09-30-2004, 02:34 PM
crazy legs's Avatar
crazy legs crazy legs is offline
Re: ebrake adjustinments
under the car...I've never adjusted through the console...
Old 09-30-2004, 04:00 PM
ok thats what i thought too. but my last car i had to take out the console to adjust it. its set so loose somehow it barely keeps the car still when im idling. got a little worried and checked the brakes but they were fine. ok well thanks
Old 10-03-2004, 11:31 PM
jones42 jones42 is offline
i have a 99 trans am and i adjusted it by taking out the center console. You are supposed to be able to adjust the tension of the cable from where the handbrake is in your console. There is no point in going under your car unless the cable is not connected at all there. (which was the case in my car).
Old 10-04-2004, 06:28 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
I have a 97 LT1 and Everything I read about it in the Chilton talks about adjusting it where the cable connects to the rotor on each of the back tires...
Just for the Stroke of it...
Old 10-04-2004, 09:25 PM
ya, but i only have a V-6 , and it has te rear drums. thanks though. i picked up a haynes manual from one of my firends so im just going to check out what it says in there. thanks for the help though guys.
