Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 09-30-2004, 01:48 PM
jchavis jchavis is offline
help with my horn
recently my horn took a dump on me. It still works but it is very weak. I live and drive in southern cali. i need my horn on a daily basis. i took apart the steering wheel to check that it wasn't stuck or jammed but it was fine. Any ideads? And where's the horn itself located?
Old 09-30-2004, 02:32 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: help with my horn
It's located on the driver's side, behind the bumper. If you take off your header panel (the fiberglass piece between the lights, and between the bumper and hood) you will see it. Another way is to get under the car and take off some of the splash guards under the drivers' side front. It's mounted to the frame. Hope that helps.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 10-05-2004, 11:26 AM
87civicfranky 87civicfranky is offline
check out the fuse box and try puting a stronger fuse.....mines had a 15 fuse and i switched it for a 25....its a lot louder now......the other day i tryed to put a ford futura 1982 horn in my car...(just for that extra kick in traffic...) but all it did was burn out the fuse.....o well.......would have been cool if it worked....
