Old 09-30-2004, 01:02 PM
frostee's Avatar
frostee frostee is offline
Send a message via AIM to frostee Send a message via Yahoo to frostee
how do i remove the steering arms?
I've been trying to remove them arms that steer the wheels right uner the car, I forgot what they were called but i cant pull it apart from the steering wheel part, I pulled off this big bolt that had a spring inside it but other than i dont see any other bolts holding it..... any help would be appreciated.
Old 09-30-2004, 04:40 PM
Hybrid1990crx's Avatar
Re: how do i remove the steering arms?
why is there an acura emblem on that 4g in your sig?
Old 10-01-2004, 12:04 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
if you mean the whole steering rack, its quite a chore.
theres a universal joint that must be loosened on the steering column. look under the dashboard, theres a plastic cover around the column and under that is the u-joint.
as far as getting the rack out from subframe, you are gonna have to take the tie rod ends off of the rack, loosen all the mounting hardware that holds the rack to the subframe, and then cuss and swear for hours as you try to shimmy, wiggle, shake, and force the rack out of the subframe.
i found the easiest way to get it out is to take the whole subframe off the car, and take the rack out on a table.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 10-01-2004, 12:30 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
^^Yea, its really a pain in the ass. Ive never tried taking the subframe off though.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 10-01-2004, 05:10 AM
frostee's Avatar
Re: Re: how do i remove the steering arms?
Hehehe, I dont know, when i bought the car, it was already on there, but it's not there anymore.
Thanx for the help guys, I hope I will not have to use a sledge hammer to remove it.
Wait a minute, we still have to remove the u-joint to remove the subframe right? That's supposed to be the easy way?
Old 10-01-2004, 01:48 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
as for taking off the steering arms, it should be similar to this
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 10-01-2004, 03:16 PM
frostee's Avatar
nice demo, but that was done way b4 i got stuck under the subframe.
