Old 09-30-2004, 11:36 AM
Hockeyfan960 Hockeyfan960 is offline
95 S-10 Buzzer Alarm
I have a 95 S-10 Pickup and the seatbelt alarm will not shut off....when the problem first presented itself, I found a disconnected ground wire near the driver's side rear tail light, after alittle sanding of the contact area and a new washer, the alarm went off and life was good again....now it is back and after redoing the rear connection and tearing things apart looking for another disconnected ground, I am stumped....does anyone have a wiring diagram for the buzzer alarm...?? What I am hoping is that I can trace the wire back to something that might be loose. The alarm comes on once I insert the key....the car is not even on....once the key gets all the way into the ignition switch the buzzing starts and doesn't shut off....Any Help would be greatly appreciated...
Old 09-30-2004, 08:04 PM
Mikado14 Mikado14 is offline
Re: 95 S-10 Buzzer Alarm
Are you sure it is the seatbelt buzzer and not the key in the ignition with door open buzzer?
Check your door plunger switches.
Old 09-30-2004, 08:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
yip, one of the door switches is broken.
Tail lights has nothing to do with the internal buzzer.
Old 09-30-2004, 08:23 PM
Hey BlazerLT, maybe he slammed the door harder that day.
Sorry Hockeyfan, I couldn't resist!
Old 10-01-2004, 02:11 PM
S-10 Alarm Buzzer
Thanks guys, I will give it a try....now that you mention it the dome light does not come on when the driver's side door is open, so the door switch might be jammed....I will take a look at it right now...
No problem about the Harder door slam joke....
Old 10-01-2004, 02:14 PM
S-10 Alarm Buzzer
The tail lights, in fact all the lights went out on me last time the buzzer wouldn't shut off...got pulled over twice on the way home from work because no taillights on....but when I applied the brakes the brake lights worked....it was crazy, but the problem was that ground wire....
Here's to hoping that the door plunge switch works....
Old 10-01-2004, 04:05 PM
BlazerLT's Avatar
AF -Advisor
Yea, it should be a door switch that is busted.
Old 10-06-2004, 07:16 AM
The Right Answer is...........
U guys hit it right on the head....Thanks so much....the peace and quiet in the truck is heaven....Thanks again...
Old 10-06-2004, 11:17 AM
BlazerLT's Avatar
AF -Advisor
Enjoy.
