Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 09-30-2004, 11:24 AM
TotalKaos TotalKaos is offline
brake light on dash
I also have a problem with this light. Around town driving and the light stays off. If you get to 35mph and up, the light comes on and stays on till the truck is shut off. No change in braking is noticed with light on or off. Anyone help me out on this problem as well?
thanks
Old 10-08-2004, 12:00 PM
I Am I Am is offline
Re: brake light on dash
you need to have codes read... it is the same idea as service engine light- but for the abs system. it is sensing an issue with a component in the abs system and will store a code.
Old 10-28-2004, 07:54 PM
adjuster adjuster is offline
Does the ABS light and Brake warning light come on or each goes on and off. The problem is sometimes in the ignition switch causing loss of power to the ABS system.
adjuster
ASE Certified Master Tech
GM Master Tech
