Old 09-30-2004, 10:46 AM
sLADe781 sLADe781 is offline
Intake Heat Shield
I was wondering what you guys thought about the heat shields that are selling on eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
Will it really block off heat from the surrounding area? Because a large part of the filter seems to be exposed still.
Old 09-30-2004, 11:01 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
hey Slade, if I had known about that shield I would of bough it before cutting my hands open fabricating one from HomeDepot sheetmetal!
yeah, its worth it, I had one from Injen on my Eclipse and it helps out quite a bit. what you wanna do is possition it so that the shield is blocking off the engine-facing side and the expossed filter is facing towards the bottom portion. that way what ever air raises from the ground up is sucked into the filter and what vapor is produced by the motor is blocked by the shield. its not an exact science but for $12 I'd get one! I would touch my filter after running the car ans after installing the shield the temperature of the filter was low enought to "feel" the difference.
Old 09-30-2004, 01:55 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Intake Heat Shield
You could get that, or you could go ghetto and cut one side and a hole into a coffy can (tin is a better thermal shield anyways lol).
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
