Old 09-30-2004, 10:11 AM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
I can't figure this %@#Z'n silverado out.
all right I got the damed tuck started. I put in a new sending unit new fuel pump new cap new rotor. and nothing so i checked the time. the rotor was pointing at 5 instead of 1 on the compression stroke. now I did take the distributor sensor out of the truck and had to bump the motor with the cap off so that I could get the mod out. so I thought that I might have slipped the rotor deck a little.would that knock it out of time. so I moved it to #1 and the truck fired up fine.the book says you cannot ajust the time. but now I have a service engine light on I reset the computer and the light came back on and know will not go out. what can I do for this.
the truck is a 1997 chevy k1500 Z71 4x4 5.7L 350 vortec.
Old 09-30-2004, 10:14 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: I can't figure this %@#Z'n silverado out.
I'd go get the code pulled and see what it is..
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-30-2004, 10:22 AM
witch pins can you put a paper clip in and pull the code
Old 09-30-2004, 11:33 AM
skipr skipr is offline
Not possible with 96 and newer OBD 2 can not be read with the blinking code method a tech 2 scan tool is ONLY way.(Yea I know, I think that sucks too) I believe you have a code 1345. Have the DTC #'s read and get back too us.
Old 09-30-2004, 12:35 PM
jeverett's Avatar
Cant you rent a code reader from Napa or somehwere like that??
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-30-2004, 01:09 PM
232 thumper 232 thumper is offline
I just *rented* one for free at a Checker auto parts (part of the Kragen Chain). All I had to do was leave a credit card number and fill out a form. Its handy to have around when doing a tune up - just in case.
Old 10-01-2004, 06:45 AM
the code is 1345 manufacture control 1 0f 2 , ignition system , or missfire. the truck is running like a top there is no sputter or anything. the book says it is the camshaft sensor in the dis. and we did take that out to have it tested so how can I get that light off or what do i have to do that sensor runs in sink with the crank sensor so say the little book. I really Appreciate all the help.
Old 10-01-2004, 10:54 AM
Ok, so it is in fact P1345. This means Crankshaft postion sensor and camshaft postion sensor corelation problem. The distributor is a tooth off in either direction. The VCM adapts to this new configuration and adjust for the new timming (meaning your engine will run fine like this ) but zero camshaft retard offset will not be obtained. To clear the light take off neg. battery cable get in truck and pump the brakes like 50 times. I don't know why this works but it does. The theory is the vcm stores a small power charge in case electrical source is disabled in an accident the air bags can still deploy with the stored power.
Old 10-01-2004, 11:44 AM
so this will remove the code i tried to do it with a scan tool but it came right back on
Old 10-01-2004, 02:31 PM
I unhooker the neg on the battery and then pumped the brake peddal like 50 times and put rehooked the battery and then started the truck, it fired up fine ran then it stumbled ( or missed) the light was out for like 1 minute the came right back on . do you think the tuck need a new cam sensor?
Old 10-01-2004, 04:20 PM
If it lit up again running means it failed and is still sensing a corelation problem.What I would do is physically turn engine to #1 TDC with dist. cap off and make sure the rotor is pointing at the 5 oclock postion (look in service manual or alldata to make sure about where #1 TDC is in relation to rotor/dist.) If it is right, then you need to start looking somewhere else, I would not go buy sensor's unless I was sure. Crankshaft sensor is about $110 and cam shaft is probally the same. The crankshaft sensor is more likly to go out than a camshaft sensor.So look for the dist. postion first and then read code again if it is 1345 still u need to run the dianostic steps assciated with that code. I f you want the step by step procedure I can e-mail it to you. It's about 2 pages.Learn frm my mistake don't go buy a sensor to replace a perfectly good sensor, can get real costly and irratatting.
Old 10-01-2004, 04:59 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Reading this thread makes me absolutly shaking in my boots to think about trying to tare into my engine for tuneup and repair problums. What ever happend to mechanical advance timeing and its ease of repair. oh god...JJ
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 10-01-2004, 06:44 PM
yes please send me the step by step it would come in handy seeing that the haynes manual does not cover it
THANK YOU
Old 10-01-2004, 07:12 PM
Ok i'm going to give you my user name and password to my Alldata suscription you will be able to view all TSB's and get detailed service info that you will never find in a chilton or haynes manual. I need your e-mail address I can't e-mail u from here I have go my AOL browser for e-mails. and I will give u the link to my log-on page as well.
Oh and the anwser to the above question about what happened to simple mechanical tune ups. The days of do-it-yourself auto repair are over, Unless you invest thousands of $ in scanners, speacialty tools, 3000 page service manuals in 5 volumes...etc. My 1979 chevy c20 has over 500,000 miles on it and never breaks down , I don't even check the oil, or any other fluid in it.
Old 10-01-2004, 07:33 PM
thank you I sent you a private message with my email on it
