| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Resistence
If I wanted to hook up 2 subs that are 4 ohm to an amp that has 1 channel and want to keep the total resistence at 4 ohms, how would I wire that? Or would I need a two channel amp?
Re: Resistence
You can't keep a 4 ohm sub with a pair of single 4 ohm subs... Why would you want 4 ohms?
www.cloudcity.deviantart.com |
They are dual 4 ohm subs. So what amp would I need to push these.
Re: Resistence
What is their rms? How much money do you have to spend?
Re: Resistence
if they're dual 4ohm that changes everything
you would wire them in series/parallel, I'm sure you can find a diagram online
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
They are 400 rms each and I have about $350 before shipping on the amp.
Re: Resistence
I would go for the first class d amp that you can find that is 800 rms at 1 ohm
Why would I get an amp that is 800 rms at 1 ohm when the subs are 4 ohms. The less the resistence the less base there is right.
Re: Resistence
where the hell did you hear that?
1ohm means wired parallel parallel that is all it means... They are dual 4. P.S. when I said where the hell did you hear that, I meant that is really really wrong. Also it is BASS not base
Re: Resistence
all your bass are belong to us
Re: Resistence
it is all your base are belong to us lol isn't it I can get the flash of that for you if you want
http://cgi.ebay.com/ws/eBayISAPI.dll...723205313&rd=1 these are the speakers I am planing on getting what amp and how should I hook them up? If you wired 2 4 ohm speakers in parallel wouldn't that give you a 2 ohm load?
Re: Resistence
THESE ARE DUAL 4 ohm subs. wire the sub parallel 2 ohm loads each and then wire both parallel together 1 ohm
So would that be as loud and have as much bass as if it were wired at 4 ohm.
Re: Resistence
I've seen that flash before, it's great
