cooling fans only work if a/c on ?????
hello everyone,,,has anyone experienced this same problem or have any ideas..i have a 95' aurora,the cooling fans will only work if the a/c is on..as soon as the a/c is turned off the fans turn off,regardless of the temperature..any ideas
Re: cooling fans only work if a/c on ?????
The dealer told me on my 98 the fans don't come on until 260 degrees AC or no AC. I find this to be a little hot. I think I'll drop the 180 thermo in and see if that helps.
Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: cooling fans only work if a/c on ?????
Thanks for the info, didn't think the dealer knew what he's talking about. Seems like I have heard the fans in the 98 run. Good thing they have forums like this or those idiots could tell you anything.
Re: Re: Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: Re: Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
Now for a no cost test. If you are able to do this yourself remove the connector from the bottom of fan relay #1 (on the firewall). There may still be a green plastic clip, if there is remove it so the tab can be depressed to unplug the relay. Once that's done you will see the four connections on the socket (not the relay). You can force the fans to operate at low speed for a brief test. Use a short piece of wire to jumper the large red and black leads on the socket, both fans will come on if the fans, wiring and relay #2 are good. |
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: cooling fans only work if a/c on ?????
