Old 09-30-2004, 09:26 AM
mmaillet mmaillet is offline
Sluggish backfiring cherokee
1999 cherokee sport inline 6 cyl. (4.0L) approx 63000 kilometers fuel inj.
Problem is A few hundred yards after startup when engine cold,the jeep
get jurky and will backfire unless I let up on the throddle or stomp it to the floor and then it will go. It starts fine and only acts up for the first
few miles then it is fine.I brought it to the dealership and they could not
find the problem ,there are no engine codes .I have done A tune up
(plugs ,wires, rotor and cap) no difference,I suspect the MAT air
sensor A ohm reading is about 20000 ohms cold to below 3000 ohms
operating temperature, this seams to be in line with the Haynes book I
have although it only gives the reading at operating temperature.
I am not sure what to do next , any help?
Old 09-30-2004, 11:13 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Sluggish backfiring cherokee
definitely sounds as if the engine mixture is too rich upon start up.
Try testing the throttle position sensor, when the engine is cold.
Old 10-31-2004, 01:50 AM
AMFRampage450 AMFRampage450 is offline
My '96 Jeep Cherokee is giving me exactly the same problem - did the advice on the throttle position sensor prove corect?
Old 11-02-2004, 09:51 AM
No it did not help next I am considering the MAT
sensor
Old 11-02-2004, 12:13 PM
gtmud gtmud is offline
Keep in mind, if it was the MAT or the TPS there would be a code, those are computer related. Check you timing. There might be a issue there, or in your distributor.
Old 11-03-2004, 11:10 AM
Changing the MAT sensor seams to have taken care
of the problem,so far it is running fine.
Old 12-02-2004, 04:09 PM
No MAT sensor did not do the trick seamed ok for A
few days but the problem is back
