Old 09-30-2004, 07:20 AM
deadring deadring is offline
coolant low light
hi,
i got a coolant low light that lights up occasionnally, i saw in another post that the sensor could be cleaned and maybe that may be the cause.. whwere is the sensor in question? if i clean it and it comes back, im gonna get the bulb out...it's useless anyway
Old 09-30-2004, 02:18 PM
parkavenuechrome parkavenuechrome is offline
the sensor is in the recovery tank
Old 09-30-2004, 09:41 PM
eespidie eespidie is offline
Re: coolant low light
where and/or what is the recovery tank
- clueless -
Old 09-30-2004, 11:09 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Your sensor is mounted to your rad and not the recovery tank.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 10-01-2004, 06:06 AM
thats what i thought, because i can,t see anything int he recovery tank...
anyway i fear it's more of a eletrical glitch than anything else.. it's too sporadic.i'll check it anyways but.. in case.
Old 10-02-2004, 04:50 PM
is the sensor on the left side of the radiator when you are looking at the engine? coze when i unplug it the light LOW COOLANT goes away.. but i think this sensor is used for the the cooling fans as well.. anway, i broke it *applauds himself* and gonna need another from the dealer.. i brok the little black thingy that holds it in place...so now it's rigged up with good old fashion handy man secret weapon : ducktape... no seriously i put a tie-rap on it.. and it's ok.. but the oolant light stays on when i replug the switch so the problem is the switch anyways..
i'll go get one at the dealer monday.. i hope it's not so pricy..
Old 10-10-2004, 07:32 PM
Clay_Bee Clay_Bee is offline
If it's like mine, it's close to the battery, very close to the Hi/Low side ac hoses where they go into the condensor connection. You have to expand a tab(s) to free it, and the space is very very tight. It's easiest to access with the rad. out of the car. Otherwise, take your battery out. I had success using a pair of 90 degree needle nose pliers (these are bent at a 90 for specialized work). When you expand the tab(s) you just have to wriggle the sensor out. Mine had green fungus/algae in it. I scrubbed it with radiator cleaner and soaked it for a bit. Worked like a charm. The strange thing is that it also trips if you don't have the correct anti-freeze mix.
Old 10-12-2004, 10:10 AM
well mine was broken so i changed it.. it cost 20$ CDN so it's rather cheap.. and now it doesn't light up for nothing.. it seems alright
try changing it.. it can't hurt
deadring
Old 10-12-2004, 10:09 PM
Not to bad. That's about what the oil sender costs in dollars U.S. I snapped that off changing the water pump. Its pretty brittle plastic.
