Old 09-29-2004, 11:44 PM
BiggyD's Avatar
BiggyD BiggyD is offline
problems after mod...
Alright, I just got done with the throttle body bypass and installing a 160 degree thermostat. the first time I tried to start it after that it took about ten tries before it would start, kinda like it was flooded? So I took it out for a little spin and once it's warm it's not doing it. Also, now it has a little higher idle,aroung 1200-1300rpm. Think I did something wrong?
Old 09-29-2004, 11:51 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
for the idle there is a screw that you can ajust on the TB just do it wile it running and youll have no prob.
Old 09-29-2004, 11:54 PM
twdz28 twdz28 is offline
Re: problems after mod...
what screw? where? what year are you talking about?
is this an LT1 car? if so I think you my have gotten some coolent in your Opti-spark... That would be why it was so hard to start at first... Your very lucky it started at all!!! Give it some time to dry out the ECM it trying to make up for it by revving alittle higher for now...
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 09-30-2004, 12:28 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
I think he's talking about the speed idle screw on carbs. If it's FI it wont have that, but I heard a problem with some people that do the bypass that their IAC gets fluid or something in it...don't remember exactly, but anyways yeah, I think the only screw type thing you can adjust RPM's with is the speed idle screw on the passenger side of the carb just below the throttle body valve's, but if you don't have a carb then nevermind that.
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 09-30-2004, 12:50 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
there is a screw to adjust your idle speed, but it's usually hidden behind a factory pressed in cap. you have to remove that first, but you can not just start adjusting the idle screw. there is a procedure you have to go through to re-program the idle speed in the ecm.
Old 09-30-2004, 04:56 PM
BiggyD's Avatar
I think it had to of been flooded. I went out this morning and it started right up so everything is alright. But just so i can check, where is the optispark located?
Old 09-30-2004, 05:01 PM
Dober89 Dober89 is offline
What car are you talking about??? I know that the TPI cars dont like 160 degree tstats too much because the computer doesnt always recognize that the engine is warmed up and it doesnt run well.
Old 09-30-2004, 05:07 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
If its still idling igh, get a 180degree t-stat
160tstat is probably the cause of your higher idle
1991 Camaro Z28
Old 09-30-2004, 05:26 PM
BiggyD's Avatar
It's a 97 trans am LT1...sorry bout that. I have another ? I heard some where that the stock LT1 intake manifold was set up for a 52mm tb but the stock tb was 48mm? I used the gasket to see and they were both the same size. so I either have a 52mm tb or the guy was full of shit.
Old 09-30-2004, 05:33 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
Re: Re: problems after mod...
i know which one hes talking about, its so you can have higher idle rev, thats what i did on my limo...
