Old 09-29-2004, 10:16 PM
90redgt 90redgt is offline
car revs w/o me giving it gas??
Whenever i start my car it starts revving up without me giving it gas? wtf? could it be the IAC? if not then what else?
1990 Mustang GT.
Old 09-29-2004, 11:22 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
how high does it rev? if it's more than 1500 i'd say your IAC gasket blew or something of that nature. or it could simply be stuck open. perhaps it's your throttle body sticking open.
take your intake tube off and make sure the tb is closing all the way. if it isn't, take it off the car and clean it thoroughly with carb cleaner, making sure to remove all deposits. before you do that, take the IAC motor off and check to see that the gasket is sealing. fill the valve cavity with carb cleaner and let it sit for a few minutes, then rinse it out. check to make sure it's moving properly. bolt it back together and fire it up, i bet it'll work much better.
and disconnect your battery before all this too, so the computer wipes itself and can re-learn the proper idle settings.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 09-30-2004, 07:35 PM
Re: car revs w/o me giving it gas??
ok thanks, will do
1990 Mustang GT.
Old 10-02-2004, 08:10 PM
CobraR2000's Avatar
CobraR2000 CobraR2000 is offline
Send a message via AIM to CobraR2000
or a simple thing as maybe ur throttle is stuck a little bit, and/or a spring or cable has broken. I'd trust what StangNut said more then me haha
1996 SVT Cobra Coupe
320 HP@ 5800RPM
DOHC 32 valve
BBK Cold Air Kit w/ 87mm MAF, March UD Pullies
My Snake
