Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 09-29-2004, 10:06 PM
fatpantha fatpantha is offline
Freaky Focus
My 2000 Focus ZX-3 started to beep when the car was off.Just a couple of beeps like I was using the keyless entry.I tried the keyless entry and the open door would lock it along with the panic.When I shut off the car the doors kept locking and the turn signal indicators will blink.This just started happening today.Also,the batterys little green light is out.Any info will be apprreciated.
Old 10-02-2004, 03:08 PM
landyacht's Avatar
landyacht landyacht is offline
If your battery isn't showing green, that just means that it's low. Unless the indicator is RED or ORANGE it's not an issue.
Sounds like something in the electrics is screwy... i'd have the dealer look at that. If these things are happening to your '00 Focus you may want to look at getting yourself an extended warranty for the car.
Good luck.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
