Old 09-29-2004, 07:39 PM
305auto 305auto is offline
slow acceleration
I own a 1983 305 camaro with an auto transmission in it. It is very slow off the line. I was wondering if there was anything that's cheap and easy to do to it to help it accelerate faster.
Old 09-29-2004, 08:04 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: slow acceleration
drive down a big hill??
nothings really cheap and easy now adays.. How does the car run? poor tune-up will make a big difference in acceleration..
other than that, start with the basics, get an air intake and a decent exhaust system..
1991 Camaro Z28
Old 09-29-2004, 10:54 PM
i recently had a tune up done. it's got a flowmaster exhaust on it, is that decent enough? would a holley fuel pump give it a little more get up and go? it sounds as though it's starved for gas when the 4-barrel kicks in
Old 09-29-2004, 10:59 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
nope, that engine only made like 140 stock. (or somewhere around that number)
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 09-29-2004, 11:06 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
a gear change would do wonders, and maybe a stall converter. but it's not exactly cheap
Old 09-29-2004, 11:41 PM
Jm93's Avatar
Jm93 Jm93 is offline
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
the LG4 made 165 hp stock, but that has little to do with his launch, because the engine made 240 ft lb of TQ. Sounds like you have a problem somewhere along the line, check your fuel lines, fuel filter, change the fuel pump and so on.
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Old 09-30-2004, 12:14 AM
also, it hesitates a little when taking off. I took it to a mechanic, and he said that it was just the edelbrock carb on it. is that true, that edelbrock carbs have a tendency to hesitate, or does the mechanic not know what he's talking about? it's got a new fuel pump and fuel filter on it.
Old 10-02-2004, 04:29 PM
NINÅ's Avatar
NINÅ NINÅ is offline
Your engine is 21 years old. Rebuild it.
REFUSE TO LOSE
Old 10-02-2004, 04:52 PM
Dober89 Dober89 is offline
Any carb thats in good working condition should run fine. Maybe yours could use a rebuild.
As far as upgrading the car goes though, a change in rearend gears would help and a stall converter wouldnt hurt too. Those 3.08 gears arent much for taking off.
Old 10-02-2004, 05:04 PM
would the stall converter and new rearend be simple to install, or would i need to take them in? i don't know too much about cars
Old 10-02-2004, 05:11 PM
4onFloor's Avatar
a rear end rebuild is something you'd probly want done proffesionally. but a torque converter swap is something you can do yourself. probly take ya 5 or 6 hours, and there's not much ya can screw up
Old 10-02-2004, 05:16 PM
about how much would it run to get it done? do you know any good sites where i can check 'em out?
