Need help with tires....
Ok, I finally started a thread for the longest time lol....my problem is I have advan sa3 16x7 and 16x8 and I need tires on them. I don't know much about tires and wondering what would fit on those specs. I know I can get 205/45/16 on the 16x7 but I am wondering if I can get the same spec tires(205/45) with the 16x8 or do I have to go wider with 215? 8 inch in mm is 203.4 so I am wondering if that would be safe too. thanks
Hiya... Need a FSM? Hit me up I'll send it to ya for FREE! I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM Sorry no 89-90 yet.... Mods: Tein Flex with EDFC Hotshot Header R32 GTR Seats Advan SA3 16x7 16x8 Apexi Dual N1 Exhaust Silvia Front End Conversion Digital Climate Control Nismo 2-Way LSD Injen Intake w/ CAI |
sure it would be safe, Id go larger on both front and back...
go with like a 215 or 225 |
I wouldnt go larger than 215F and 235 R... When i get my 16x7s im going to run 205/55
Re: Need help with tires....
just curious why would you go larger? or wider in a sense?
Bette tration, wider=more grip. (and look good) And to learn about tires go to http://auto.howstuffworks.com/tire.htm , a very useful link, helped me understand what all the numbers mean. If you learn this you ll be able to pick perfect tires for your needs.
VR6> Anything FWD sucks for understeer? Swaybars do magic. |
I know what each means...just didn't know if it would fit right or if there would be problems. Good link though. Thanks...that helped me learn about lsd and stuff.
im running 16x6.5 and got 225/50 all the way around, 225 50 is probably the widest you would want to go on the front and 235 on rears get 50 or 45, if you gow tih 55 then the tire will be to tall.
Well the thing is, I might be able to get some cheap yokohama 205/45/16 for my rims and was just curious if it would fit the rear 16x8's. I know they would fit the 16x7's with no problem...it was just I didn't know if it would fit 8 cause 8's are 203.4 mm which is very close to 205 mm tires. thanks for the help...much appreciated.
if you go too wide without a stiff sidewall the Tread will squirm and it will feel like ass transitioning. also on a taller tire the tread will roll under (hence why you sometimes see shoepolish bands on the sidewall.) either way a huge ass tire on a small rim isnt a good thing
sideveiw pics??? |
of my car?? or the rims? I haven't install the rims yet cause I don't have tires on them. I am thinking of getting 205/40/16 all the way around. Is that going to be too tight on the 16x8s?
