Old 09-29-2004, 05:41 PM
SteveNixon SteveNixon is offline
MAF sensor
Hello to all
Since there's still no luck on cartrackers, and i know alot of members have come here, this seems to be our new home.
anyways, to my question
how do you clean out the MAF sensor. and what do you recommend using?
thanks,
Stephen
Old 09-29-2004, 06:52 PM
rodeo02 rodeo02 is offline
Some of the G-roo's may have a better method, but I've had good luck with cotton swabs & a spray can of electrical contact cleaner. Just be really careful/gentle around the actual p/up wire(s).
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 09-29-2004, 10:11 PM
12Ounce 12Ounce is offline
Re: MAF sensor
I have used Radio Shack's "Precision Electronics Cleaner"(#64-4345). Various alcohols, naptha, acetate propelled by CO2. They claim it doesn't leave residue. Seems to work OK, .. but then I haven't used it that often.
Old 09-30-2004, 08:37 AM
ModMech's Avatar
ModMech ModMech is offline
Re: MAF sensor
www.crownvic.net/tech/cleanmaf.html
Old 10-01-2004, 07:10 PM
KPVSR KPVSR is offline
Just to stay on the safe side I personally would not touch the wires with a cotton swab or anything else. A good dousing of electric contact cleaner should clean them without rubbing.
Old 11-29-2004, 02:21 PM
gschretter gschretter is offline
B-12
B-12 Carb cleaner.
Did my MAF and saved the day.
Make sure you unplug the batter and let dry before starting.
Remember a MAf sensor is a heater.
The more air passes over the coils the cooler the wires will be so the MAF applies more volts which mean high air flow. More air flow more gas.
Old 11-29-2004, 05:49 PM
busboy4 busboy4 is offline
Re: MAF sensor
The more air passes over the coils the cooler the wires will be so the MAF applies more volts which mean high air flow. More air flow more gas.<<
Thanks for that!
