i HAVE A 95 MAZDA MILLENIA,,,the car shuts off very often.. especially when the engine has gotten warm,,, i have replaced,, the throttle sensor and an oxygen sensor, replacing the fuel filter helped for a while but its the same problem,,spark plugs have been switched but i didnt replace the wires,,, there is also a strong gas sent after the car has been sitting for a while.. it runs fine,, when i do get up to 50 or 60 mph but it still may bog down and shut off,, also my check engine light is on,,but the results came back (passed) after being tested at autozone.. i am confused on whether its a fuel pump gone bad or a electrical problem
Re: Millenia Troubles
OK, I had the Exact same problem.. check the resistance of your primary and secondary windings on your ignition coil.... thats most likely the problem... used, you can find one for around $250 pretty dang expensive. If you have the AIM instant messenger, my s/n is ApleJuce14. I can tell u how to do that all if u need.
