Old 09-29-2004, 03:13 PM
HaulAss HaulAss is offline
Send a message via AIM to HaulAss Send a message via Yahoo to HaulAss
Exclamation Fog Lights
Ok so my fogl ights burn out all the time and the guy at O'Reillys usually replaces them but hes not working there any longer. Any ideas as to how I replace these?????
Thanks!
Old 09-29-2004, 07:54 PM
JTrujillo86 JTrujillo86 is offline
Re: Fog Lights
I think you have to remove them from the back of the assembly.
Jeremy
Old 09-30-2004, 09:10 AM
Guitarz Guitarz is offline
Yes, just quarter turn, take the connector loose , and connect new lamp. Quarter turn back in oppisite direction. Only fits one way ,I think.
Tom
Old 10-06-2004, 09:54 AM
MNAlero MNAlero is offline
My fog light been out forever...also been looking for a good fog lights. Any recommendations?? I want something bright.
thx in advance,
gen
Old 10-07-2004, 08:54 AM
Do you want to replace the whole light or just the bulb?
TomF
Old 10-07-2004, 02:05 PM
well...I guess, whole light - if its under $100?? if its too expansive..then just a bulb. Which one or brand would you recommend?
thx
gen
Old 10-08-2004, 08:39 AM
Not sure on all the brands. Different bulbs are available just about anywhere, with different intensities. White, blue ect. Not sure how new ones would work as far as mounting. Check out ebay. They have both most of the time I've looked.
Good luck, TomF
Old 10-30-2004, 03:10 AM
puppyboi puppyboi is offline
fog lights
hello all,
i have looked into the fog light for my 2001 alero. i found that at "auto zone" they have a large stock and can also special order fog lamps or bulbs to replace and mount proper on your alero.
may be worth calling or going down to your local auto zone!
thank you all.
u r special
from,
the pup
Old 03-06-2005, 12:27 PM
ttwotees ttwotees is offline
To replace foglight bulb
Remove the healight by raising the two guillotine type locks on each
side of each headlight, pull healight out, disconnect elec. plug and two
bulb twist locks, remove headlight and you can then access the fog
light below very easily.
ttwotees
