Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-14-2002, 12:33 AM
Rein Rein is offline
Send a message via AIM to Rein
Need to lower my car.
I've got the rims, I've got the tires...What do I need to lower my car? I've got stock everything right now. I'm not looking for anything special at the moment, just simply to lower my car about an inch. I'm low on cash and will eventually get a good suspension system, as for now, I need the bare minimum
Old 02-14-2002, 01:52 AM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
bare minimum, you need lowering springs. That should cost around $100. It'll be kind of a harsh ride though, so if you have a little more cash, you would probably want to consider new struts. That's a little more costly though. Anywhere from $300-600?
AF Nordic Crew #3
Old 02-14-2002, 02:44 PM
Just for me to get this straight, tell me if I'm correct....struts=shocks and lowering springs= coilovers?
Old 02-14-2002, 04:08 PM
94civic's Avatar
94civic 94civic is offline
no you have coilovers, which are adjustable and you have the lowering springs which are non-adjustable. These are already set on a pre-determined height. i think that struts and shocks are the same.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 02-14-2002, 05:18 PM
Rice-Rocketeer Rice-Rocketeer is offline
No, struts are the shock absorber that's a part of the strut/spring combo found on double wishbone suspensions. Meaning you can't drive the car without the strut. A shock is the seperate part of other types of suspensions where the spring and shock are seperate. So you can remove the shock in this case and still be able to drive the car.
As for why you need to lower your car? You don't but lowering springs and struts help lower your cars center of gravity, help keep the full grip of your tires on the road and reduce bodyroll while turning. And it looks pretty cool too.
Lookin at my gucci, it's about that time...
Old 02-14-2002, 06:23 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
just do the ghetto 60's hotrodder method and torch your springs.
sike
just wait and save and get it all done at once. you'll thank yourself in the long run unless your a glutten for punishment.
Old 02-14-2002, 06:26 PM
NEED4SPEED NEED4SPEED is offline
Dont forget the camber kit.
Old 02-14-2002, 06:48 PM
amoney805 amoney805 is offline
Send a message via AIM to amoney805
you probably wouldnt need a camber kit if your only gonna drop it an inch. as for the springs youd probably want to spend more than 100 bucks, cause you pretty much get what you pay for.
Old 02-14-2002, 06:50 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
he wont need a camber kit if he's only lowered 1 inch. Anything about 1.8" or 2"..he will need a camber kit.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 02-15-2002, 02:07 AM
If I just bought new coilovers, would the stock springs still be involved in the suspension? Basic question is what else do I need with the coilovers?
