Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-29-2004, 02:10 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Who uses compression braking
I was just wondering how many people use compression braking. I know it saves your brakes. If you do use it, do you go straight down through the gears or do you skip some, I have seen some people who go 4th to 2nd and then brakes.
Thanks,
Nick
Old 09-29-2004, 07:27 PM
ProjectPhantom's Avatar
ProjectPhantom ProjectPhantom is offline
Re: Who uses compression braking
burns alotta clutch tho, i'd rather not.
Old 09-29-2004, 07:28 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
not good. just use the brakes. they're easier to replace than a transmission
Old 09-29-2004, 08:56 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
If you rev match it wont hurt the clutch as much.
I do, btw.. moreso than I use the brakes.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 09-29-2004, 09:20 PM
Flava888's Avatar
Flava888 Flava888 is offline
i only use it if i gotta stop faster, use em both kinda, as long as u rev match, like he said, its fine
then again, 4 wheel disc, drilled and slotted work damn good too
Old 09-29-2004, 09:28 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
heel-toe
Old 09-29-2004, 09:45 PM
Well see, I have bad brake pads, they just started squeeking, and I got new ones, but I have worse than stock wheels(guy I bought it from said the stocks got stolen, I think he sold them) but it has one big bolt in the center of all 4 lugs, and I don't have a socket to get it off, I tried a channel lock but it didn't work. Time for a new socket, I guess. So for now I am just using compression braking down to like 10 mph, then pushing the brakes.
Old 09-29-2004, 11:19 PM
rev match? never heard... hows that done?
Old 09-30-2004, 04:09 AM
Prelewd's Avatar
Re: Re: Who uses compression braking
Match the engine speed with the vehicle speed in a selected gear. For example. If you are doing around 40 mph and you wanted to be in second gear for the purpose of slowing down using your engines compression, you would rev your car up to about 5800-6000 RPM and release the clutch. If done properly, you will experience no forward or backward surge until you lift off the gas and a smooth clutch engagement.
It takes a bit of practice to learn to do by feel, but you will get the hang of it. It is second nature to me right now, but I still misplace the tach needle sometimes. Have fun.
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
