Old 09-29-2004, 01:51 PM
calamari925's Avatar
calamari925 calamari925 is offline
Send a message via AIM to calamari925
Question Will This Amp Work With These Subs?
so basicly what i need to know is will this amp a 2400w 2 channel Legacy LA2070 with these specs
Frequency Response: 20hz-30khz
Thermal Protection
Overload Protection
Short Circuit Protection
Dimensions (hxwxl):2.6?x10.4?x19?
2 Channel Amplification
2 x1200 Watts Output
1 x 2400 Watts Bridged output
2400 watts Total Output
Remote Control Bass Boost
(0-+ 18 db @ 60hz)
Fully adjustable electronic Crossover Network
Soft Turn on/off Circuit
2 Ohm stereo stable
Bridgeable into 4 ohms
Variable Gain Control
Remote Turn on/off
Power on LED Indicator
LED Protection Indicator
15.54 lbs
work with these subs two 12 inch punch XLC rockford fosgates in a ported box with these specs
Type Component
Elements 1-Way
Function Subwoofer
Size 12"
Nominal Power Handling 200 Watt
Powered Non-Powered
Technical Features
Peak Power Handling 400 Watt
Sensitivity 89 dB
Impedance 4 ohm
i just want to make sure it wont blow the subs and yes i have already got hell for getting the legacy but whats done is done i just want to know will it work good and will a 8 gauge power wire be ok thanks in advance for any help or comments
Old 09-29-2004, 01:58 PM
hotwheelsgt's Avatar
hotwheelsgt hotwheelsgt is offline
Send a message via MSN to hotwheelsgt Send a message via Yahoo to hotwheelsgt
Re: Will This Amp Work With These Subs?
that amp seems like a little much for those subs doesnt it?
Old 09-29-2004, 02:01 PM
At First Glance Yes But From What I Hear It Does Not Put Out As Many Wats As It Is Rated Which Is Why I Am Asking If It Will Work I Mean I Can Always Give The Subs Less Watts I Don't Need To Use Them All
Old 09-29-2004, 02:06 PM
i dont see why it wouldnt work just turn the amp down
Old 09-29-2004, 02:14 PM
Yeah Of Course I Can Do That But I Just Want To See If It Will Work At Full Power Or Will I Need To Turn It Down So Im Saying If The Amp Does Not Put Out All The Wats It Says It Will Then Maybe I Can Leave It At Full Power And If It Really Does Put Out All That Power Will I Need To Turn It Down..... Also I Was Wondering If The 8 Gauge Power Wire Was Good Enough And How Can I Get The Max Bass While Steel Being Able To Hear The Words Clear You Know With Out Distortion I Just Have Some Boston Fx's In The Front Doors Stock Tweets Int The Doors And Stock Speakers In The Rear Doors
Old 09-29-2004, 02:21 PM
Also I Might Add That I Dont Want To Pay For Anything Else What Can I Do With What I Have?
Old 09-29-2004, 02:56 PM
if you leave the amp all the way up they are gonna blow. the amp may not put out wut it says but it still has enuf to blow them the stock stuff shold be fine i mean come on now the subs are only 200 watt nominal
Old 09-29-2004, 03:34 PM
Ok Well Good To Know Thank You So Do You Know What Part Of The Amp I Need To Turn Down In Order To Make Sure The Subs Dont Blow? Is It The Gain?
Old 09-29-2004, 03:35 PM
Also Anyone Else Have Any Ideas Or Comments?
Old 09-29-2004, 04:09 PM
yes its the gain
Old 09-29-2004, 05:05 PM
well i guess no one else has anything to say
