Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-29-2004, 01:20 PM
b18 ls's Avatar
b18 ls b18 ls is offline
Banned
Question on pistons
I'm building a b18b n/a set up (possibly going ls/vtec in future). I had planned on useing balanced Spoon ctr pistons, but I'm starting to hear more good things about JE pistons. Does anyone have experience with either. Also, I don't plan to make more than 195 at the wheels when I'm done, so do I need new connecting rods? Will it be better to have them?
Old 09-29-2004, 03:17 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
Re: Question on pistons
w/195whp je pistons w/ be extremely reliable. id jsut go with je pistons&eagle rods combo. you can get them together for like $780
Old 09-29-2004, 05:11 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I hope you do know its gonna take a bit more work to get 195whp with the LS right?
Old 09-30-2004, 07:39 AM
b18 ls's Avatar
Banned
Yeah I know, thats why I'm kinda leaning toward a ls/vtec set up. I just don't want to sacrifice reliability.
Old 09-30-2004, 12:03 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Do sum research on Arias pistons before you completly consider JE.
Old 09-30-2004, 10:15 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
what happened with ur crower cam setup? i thought u were gonna represent with the NON-vtecs??? well LS/VTEC is still awesome. good luck.
well im probably gonna get a set of PR3 pistons (from 99-00 civic si). they'll fit right on my LS rod w/o any milling done. the ITR and i think the CTR will require the shaving off a lil bit on the LS rods to make them fit
www.MEDIUMRACING.com
Old 09-30-2004, 11:29 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
check out this website for some good rods and pistons... http://www.dh-racing.com/
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 10-01-2004, 10:00 AM
b18 ls's Avatar
Banned
Originally Posted by boosted k20
what happened with ur crower cam setup? i thought u were gonna represent with the NON-vtecs???the ITR and i think the CTR will require the shaving off a lil bit on the LS rods to make them fit
I'm still trying to get as much as I can out of the non/vtec set up, (just to be the underdog) but if I cant get close to 195whp, then I'm going to consider the ls/vtec. I'd much rather keep the no/vtec theme going though. I got my vavle springs and retainers, but I still havn't found a great deal on the 62403's. I'm not working at my second job so, I'm only buying parts if I get crackhead deals on them.
Any way, you said the ctr pistons won't fit right in? So I'll have to get new rods! Thanks for the help.
Old 10-01-2004, 12:06 PM
Mannyb18b's Avatar
How much are a set of PR3 pistons?
Old 10-01-2004, 12:07 PM
mellowboy's Avatar
50 bucks
Old 10-04-2004, 08:07 PM
PR3 pistons u can get for pretty cheap especially if u know someone that works at honda.
b18 ls, u can keep ur LS rods with the CTR pistons. u just need to take em to a machine shop so they can mill the top of the rod a little bit. u need to take the rods and pistons to a machine shop anyways for them to press out the old pistons and put in the new ones.
Old 10-05-2004, 12:29 PM
b18 ls's Avatar
Banned
What are pr3 pistons?
Old 10-05-2004, 03:57 PM
Mannyb18b's Avatar
"well im probably gonna get a set of PR3 pistons (from 99-00 civic si). "
Old 10-07-2004, 10:06 PM
LSfrankenstein LSfrankenstein is offline
Banned
Actually all you need to do is put the pistons in a vice with the pin oriented vertically and use a standard nail punch and hammer to punch those suckers out. No need to spend all that money at a machine shop, besides most machine shops are over priced and they dont really know what they are doing. they would probably damage ur pistons, just do it urself
Old 10-08-2004, 10:01 PM
well that might work for taking out the pistons, but press n them back in can be tricky. i wouldnt do it myself by using a hammer and a nail punch. u might end up crack n the psiton doing it like that. a good machine shop will heat up the rods so they expand, then they can easily slip the wristpins onto the rods. my local machine shop charges $60 to take out old pistons and put n new ones on ur rods.
