Old 09-29-2004, 12:22 PM
4getredline 4getredline is offline
Good Turbo Setup?
Hi guys i have a b16a and after a bunch of research and talking with people this is what i got for a engine setup (i would apreciate any help if there is a better set up) i want to run high boost probally around 12 psi or higher if i can get away with it i was thinking about getting a stroker kit from Eagle making it a 1.8L and droping compression to 9:1, sleeving it with darton sleeves, skunk2 turbo cams, and sending the head to import builders to have it ported and the valvetrain upgraded to the IB Spec Head Package.
Old 09-29-2004, 01:07 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Good Turbo Setup?
If you know about importbuilders then theres no better set up than what they've suggested.
Old 09-29-2004, 08:16 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
if you wanna run high boost you r gonna have to drop the compression ratio lower then 9:1
Old 09-29-2004, 10:21 PM
mellowboy's Avatar
If you wanna run low boost you gotta keep the compression high
