Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 09-29-2004, 11:55 AM
joe dm joe dm is offline
2001 Trooper Transmission problem
I have 61,000 miles on my 2001 Trooper and I just had the automatic transmission fluid changed. I've noticed since then that it has been behaving strangely. It shifts hard into 2nd sometimes. There will be a pause, and when it hits it is hard enough to chirp the tires. It has also been dropping RPMs momentarily on the highway when in cruse control. At times it seems that shifting between other gears is rough as well. Once or twice it has really revved up before settling into the next highest gear.
Could this be a problem stemming from the transmission fluid change, or am I looking at a more serious problem? I was rear ended a few years ago, and I am hoping this isn’t a lingering problem from the accident.
Any advice would be helpful.
Old 10-02-2004, 09:37 PM
travelman travelman is offline
http://forum.planetisuzoo.com/viewto...e3b88e41958c75
Look at the above link. Mine was doing pretty much exactly what yours was doing, including dropping out of cruise control. The fix noted in the link worked for me.
Old 10-02-2004, 10:11 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: 2001 Trooper Transmission problem
I would be willg to bet that whoever serviced the tranny did not put enough fluid in it stop driving iy before you destroy it fluid needs to be filled with vehicke running in neutral... any other way is wrong!
