Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-29-2004, 11:44 AM
wajmort wajmort is offline
Headlights not working
I just purchased a '95 Grand Cherokee Laredo and the headlights won't come on. Bulbs are good because the headlights come on when checking high beams, although high beams won't stay on. Have to hold lever back.
Heard somewhere that it might be a relay problem. Is this correct?? What relay should be replaced and is it located in the fuse box under the hood??
Chilton's was no help.
Old 09-29-2004, 05:58 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Headlights not working
do they work when u turn them on (NOT ON AUTO), when they are in the ON posistion?
Old 09-30-2004, 12:54 PM
dksob81,
No, I tested both switch positions and they didn't come on during daylight or nighttime hours. All the other lights (front and back) come on as expected.
When I pull the turn signal lever, the high beams come on but won't stay on. That's how I determined the bulbs were good.
Any thoughts???
Old 09-30-2004, 01:02 PM
does the lever CLICK when u pull back on it as to turn the HIGH BEAMS on?
Old 09-30-2004, 07:58 PM
no, it doesn't. Am I missing something here?
Old 10-05-2004, 02:30 PM
mkvapil mkvapil is offline
Did you check the fuse? My 99 Jeep have fuses for each headlight. One fuse for high beam on passenger side, one for low beam on passenger side, and so on.
Old 10-06-2004, 05:48 AM
Cam7 Cam7 is offline
You might try checking the light switch and the dimmer switch. I had a bad connection at the dimmer switch do the same thing. Its located on the steering column a little hard to get at.
Old 10-12-2004, 09:30 AM
Smile
I replaced the turn signal switch and now they work. Thanks to all for your input.
Old 10-13-2004, 01:36 AM
Was it the Turn signal switch or the dimmer switch?
