Simple problem. 1996 Plymouth Voyager Sometimes it starts (cranks over) - sometimes it doesn't I can hear the starting relay clicking. The starter relay still clicks if I am out of park or neutral. I can jump directly to the starter solenoid and with the key on, she will start. I suspect it is the neutral/park switch. Where the heck is that switch? What else could it be?
Re: Intermittant starting
The starter relay will not click if the nuetral switch is defective. So I would look at connections or starter.
Try this: put the car in drive and hold your hand on the relay. It will click when you turn the key to the start position.
I can jump directly to the starter solenoid and with the key on, she will start. The connections to the starter are fine. I can get it to start now by holding the key to the start position and banging on the dash board left side. LOL |
I still need help here!
