Old 09-29-2004, 11:27 AM
jwaters jwaters is offline
Send a message via ICQ to jwaters Send a message via AIM to jwaters Send a message via Yahoo to jwaters
Accesorie, but no on!!!!
I am having one heck of a problem figuring out what is wrong. I can not get the ignition to go to the on possision in my 94 Jeep 4.0L Cherokee. I can put the key in the ignition and turn it back and the Radio come on but when I try to turn it to the on position it does not start, it seems to be locked.
Is it that I neeed a new ignition switch or is there something else wrong. Any help would be nice. Thanks
Old 09-29-2004, 11:46 AM
kmerian kmerian is offline
Send a message via Yahoo to kmerian
Re: Accesorie, but no on!!!!
Yep, sounds like your ignition switch
Old 09-29-2004, 12:05 PM
Are you sure cause I can move the gear shifter when I turn the key forward but it is not in the on position.
Old 09-29-2004, 12:47 PM
Dale Aeppli Dale Aeppli is offline
HI, TRY SPRAYING SOME WD 40 INTO CYLINDER LET SOAK A LITTLE. HOPE THIS HELPS DALE [email protected]
Old 09-29-2004, 12:54 PM
I will try that and see what happens and let ya know, thanks
Old 09-29-2004, 01:09 PM
Its a no go on the WD 40 dude. Anyone else have any suggestions??
Old 09-29-2004, 01:36 PM
Saudade's Avatar
Saudade Saudade is offline
As kmerian said, your switch is bad. Not the lock cylinder part but the electrical switch.
Old 09-30-2004, 07:44 AM
Thanks for all your help guys. I found the problem and it was not the switch it self. The problem was the lincage from the cylinder lock, it got stuck and all I had to do was jiggle the linkage back and forth on the column.
