Old 09-29-2004, 10:58 AM
osok_deadeye_21 osok_deadeye_21 is offline
Battery ?
What is the best battery to use if you have a subwoofer stereo system? My battery is very weak and worry that one morning going to work it wont start. When I use my blinker it fluctuates, and when I use my lights and rear defroster it is almost below half way.
Old 09-29-2004, 11:29 AM
Getsum3kgtsl Getsum3kgtsl is offline
Re: Battery ?
That's the alternator. When the car is running, you're not using electricity from the battery (only used to start up the car) you're using electricity from the alternator. As long as your voltage is around 12V you should be fine (somebody correct me if I'm wrong). But if you're worried, you can buy or get a custom built alternator or go the cheap way and get a farad cap. You'll connect the cap before the amp that supplies the subs. It stores charge from the alternator, so when you hit deep notes that use alot of power, it takes the power from the cap and not the alternator, so no voltage drop.
Old 09-29-2004, 11:32 AM
sLADe781 sLADe781 is offline
Re: Battery ?
Yeah, my friend was telling me something about a capacitor for your system so that it won't drain your battery as bad. Might want to look into that....
About the alternator, my dad once took 2 broken alternators and salvaged the parts to make one that works. Hehe Haven't broken since as far as I'm aware. Pretty cool eh?
Old 09-29-2004, 11:55 AM
how much does this stuff cost?
Old 09-29-2004, 01:10 PM
Re: Battery ?
I'm thinking from around $80 to $150 for the capacitors, alot more for the alternator. I know you can add another battery just for the audio, but I only see that and the custom alternators on competition vehicles. I had a Grand AM GT with 3 RF 300watt amps and never got the cap,alternator, or extra batt., I just tried not use too many accessories at once w/the radio on. A/C and radio full blast meant a new alternator, but my voltage would be around 10V
Old 09-29-2004, 01:21 PM
man sounds like a pain.
Old 09-29-2004, 02:21 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
well if you want to buy a high performance battery, Optima makes the red top, blue top and yellow top batteries with some serious new gel technology that can help sustain your system. As for the fluctuating when you turn on the blinkers....dont worry, my car does that, its perfectly normal.
Old 09-29-2004, 03:00 PM
yeah ok so you are saying that as long as i have 10v i will be ok? I am at about 12v
Old 09-30-2004, 05:09 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: Re: Battery ?
you need a minimum of 13.2-14.5 volts to keep your battery charged any less and you are in trouble as the fuel pump works on regulated voltage so if you are booting it down the road with low voltage coming out of the alternator you are not getting the correct amount of fuel to feed you car and the concequences can be disasterous so watch out!!!!!!!!
a farad cap is a perfect solution but get that alternator checked out.
hope this helps
brian.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 09-30-2004, 09:50 AM
Neoscarecrue Neoscarecrue is offline
Re: Battery ?
hook your subs up to your alternator,you shouldn't have any problems unless your runnin competion quality power.
Old 09-30-2004, 10:27 AM
Re: Re: Battery ?
Hmm...never heard of that before. How would one go about doing that? And would a cap still be needed if the sub was hooked to the alternator?
Old 09-30-2004, 10:30 PM
Re: Battery ?
you don't actually need to hook it to the alternator since it will recharge the battery also.a cap is the best bet
Old 09-30-2004, 10:33 PM
Gateway's Avatar
Gateway Gateway is offline
Re: Battery ?
hooking your subs up to the alternator? you are a retard
and FYI, if you do get an optima battery, you want the yellow top for audio systems.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 10-01-2004, 01:55 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: Battery ?
Uh no, when the car is running, you ARE using electricity from the battery. The alternator is what constantly recharges your battery while driving so it doesn't drain.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
