Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-29-2004, 09:05 AM
rcmodeller rcmodeller is offline
1988 Crown Vic EFI Computer
The EFI computer in my 1988 Crown Vic has gone bad. Can anyone tell me where it is located? I need help! Please e-mail me at [email protected].
Thanks,
Bob Mason
Old 09-30-2004, 04:06 PM
radioman2002 radioman2002 is offline
Please give more info, is the engine a 5.0 efi or 5.8 carb. If it is the former the computer is located under the dash left of the brake pedal. You must remove the bolt that holds the wiring harness to it from the engine compartment. Look above the wheel well, behind the hood hinge. Once you have the bolt loose you can remove the plastic clip under the dash, bend the sheet metal bracket and it should fall out. I have changed many from engine swaps and have only had one go bad in over 10 years. What makes you think it's the computer, there is usually a dozen reasons other, than the computer bad, for the engine to not start.
