Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 09-29-2004, 07:53 AM
EclipseSage's Avatar
EclipseSage EclipseSage is offline
Send a message via AIM to EclipseSage
GSX/GST turbo in 2000+ eclipse
Does anyone know if it would be possible to get an old GST/GSX turbo and put it in a 2000 GS, i also wanted to try and convery my car into AWD. I'm wondering if i can get everything i need for the conversion from an old GSX. I plan on getting the parts from a junkyard or ebay, it seems this method of putting a turbo in could be alot cheaper.
Old 09-29-2004, 08:54 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: GSX/GST turbo in 2000+ eclipse
why not just go buy a GSX?
Old 09-29-2004, 08:56 AM
http://www.club3g.com/forum/showthre...hlight=GSX+AWD
that will give you an answer on the AWD part.
you could probably use the turbo but i wouldnt. if im not mistaken, the stock turbo is like a 16g. and the stock GSX has like 210hp. that turbo is pretty small
Old 09-29-2004, 12:17 PM
Ya i know it is small but it will be good for now and inexpensive and then i can just upgrade the turbo later, how is that not a good idea?
Old 09-29-2004, 05:23 PM
i guess i can see where your going with that.... but i would stay away from ebay.
Old 10-03-2004, 03:17 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
what do u mean by a GST/GSX turbo?
Do u mean a T-25 turbocharger, or the 4G63 engine with the T-25?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 10-03-2004, 04:19 PM
the stock turbo that is in the GST and GSX models
Old 10-04-2004, 05:20 PM
crazy_ugly_coyote crazy_ugly_coyote is offline
Banned
Send a message via AIM to crazy_ugly_coyote
the older eclipse's 1 and 2 gen's are positioned opposite to ours. i doubt you could get it in there without alot of custom work. wouldnt be cost effective. just turbo it!
Old 10-04-2004, 06:43 PM
i alrdy had a shop look at it and they were the ones that suggested it to me even, they said it would be much less inexpensive to do then a new full turbo, and not hard to put in either.
Old 10-08-2004, 03:10 AM
Shpyder's Avatar
Moderate moderator
all you need are flange adapter kits for whatever turbo u want to run, and the matching exhjaust mani.
Old 10-09-2004, 03:46 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
ummm if ur gunna turbo from scratch, go w/ the big 16G turbo or something along those lines, don't use the stock one, because its REALLY SMALL for the kinda power you'll want to make, however they ARE a dime a dozen if you know where to look, imo go w/ the AAI turbo kit
Don't act like you don't love it.
503/2000
Old 10-09-2004, 08:39 PM
Yes ofcourse a bigger turbo is better, but your missing the point of $$$. I dont have 5 grand to spend on a turbo, i can get a gst/gsx turbo put in for under a 1000 and upgrade later when i have the money. And any turbo in my car even a small stock turbo is gona make a sizable difference.
Old 10-10-2004, 03:07 PM
Shpyder's Avatar
Moderate moderator
well, i disagree with elchicoloco86....the T-25 has become infamous for being really small, but with the right tuning, it can put down sizeable power and has minimal spool time of any turbo out there. 16Gs are a lot bigger, but running high psi on non-4g63 engines may pose a engine-busting hazard... the 4g63 is capable of withstanding enormous boost without upgrading the internals when compared to other engines out there, so saying a 16G would be a better option is baseless if you cant run over 6 psi on it. Im running my T-25 at 17psi, and Im loving it.
I would reccomend the 14B....its a little bigger, but no by much, and the price difference between the t-25 and the 14 b is minimal, since both were stock parts on mitsu cars.
Old 10-11-2004, 02:26 AM
Sleepr awd's Avatar
i was pretty sure the t-25 maxed at 15psi...but sure, anyways a 16g you can pick up for 600$ not...5000$... i'm not saying a t-25 is bad at all, i just don't think it is large enough to fit the application, also larger turbos push more hp at lower psi...iono why, they just do so instead of turning up the boost, just go slightly larger and reap the benfits of a larger turbo or at least a 14b ported (1g GS turbo and GSX)
also, if your thinking you can do your entire turbo kit for 1000 not including labor...you have very high hopes, cuz you'll still need to tune it w/ at least a greddy piggyback system and that is half your 1000$ budget right there
good luck
503/2000
Old 03-08-2005, 11:06 PM
Reveloution00 Reveloution00 is offline
Ok i hve read all this information, i am in sort of the same situation would it be better to look for a a turbo from a gsx or gts or make a custom for the eclipse 00 2.4
Aem CAI
just need to install Mangaflow Performance Catback
