Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-29-2004, 07:08 AM
jc-pa jc-pa is offline
2.56 to 3.42 calibrating speedo.
I plan on changing the rear ratio in my 95 caprice wagon with a 4L60E transmission. I'm concerned about changing the speedo, I see lots of what look to me like hokey buffers you put into the vss ckt but I would like to do it with the cars own software or hardware. The problem is I don't know where to get credible info on this subject. Thats why I'm here. Is this a straight forward modification,(relatively easy) Or something other?
Thanks
Jerry
Old 09-30-2004, 08:23 PM
TommySS TommySS is offline
Re: 2.56 to 3.42 calibrating speedo.
If you're car has OBD III diagnostics (I think it does), then the dealer can do it with a Tech 2. The older caprices use a gear-driven speedo so a gear change is needed there.
Old 09-30-2004, 08:55 PM
obdIII? It has an obd1 connector but the eeprom is part of the ecm and can't be removed, it needs to be flashed.
I'm concerned the dealer will have problems with a 3.42 because the car wasn't built with 3.42s only 2.56 and 2.9?. The 4L60E uses a tone ring on the output shaft of the trans. instead of a gear driven vehicle speed sensor.
Old 10-01-2004, 07:22 PM
The dealer can flash it to compensate for the 3.42
Old 10-02-2004, 08:39 PM
Thanks TommySS
Old 10-03-2004, 10:24 AM
Let us know how it comes out, m-kay?
