Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 09-28-2004, 11:58 PM
krappy krappy is offline
cam timing
iv heard a lot about cam timing but im not sure quite what it is. i know how to do it on my car(i think) but to what degree and what gains should i expect as well as what down sides might there be?
Old 09-30-2004, 02:29 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: cam timing
cam timing is what controls the opening and closing of valves. there are two ways to control the valve timing, new cams or adjusting the timing gears, or both. ether way this is staring to past simple bolt-ons.
you can buy new cams specially shaped with different lobe profiles to allow the valves to open or close at different times, or longer or shorter periods of times. changing the torque curve MASSIVELY
to adjust cam timing you would need to buy adjustible cam gears, then tune on a dyno. the cam timing sets the placement of the torque curve, so you can focus the torque curve to what you need, more torque? more HP? low end? top end? any gains would depend on other mods, the cam shape/arrangement, and how well the engine is tuned.
for example
more cam info.
http://www.elgincams.com/campaper.html
adjustible timing cam gear at bottom page.
http://www.spswebpage.com/store/inde...dcore%20Power&
Old 11-22-2004, 10:52 PM
tricksaturnsc2 tricksaturnsc2 is offline
Re: cam timing
Best thing is adv intake 2, retard exhaust 2.
Old 11-26-2004, 10:20 PM
Zgringo Zgringo is offline
Re: Re: cam timing
Where do you get that figure from. Tell me how do you advance your intake and retard your exhaust on a single cam engine.
The best advice is to explain to the cam grinder what you have, and what you intend on doing and follow his advice
Old 12-08-2004, 01:54 PM
sracing's Avatar
sracing sracing is offline
Re: Re: Re: cam timing
Simple, break the camshaft into multiple pieces.
But why one would retard exhaust and advance intake in that scenerio is a bit strange anyway.
Jim
SR Racing
Old 12-08-2004, 03:16 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: cam timing
Get an aftermarket cam with the lobes machined to your desired specs.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 12-28-2004, 07:39 PM
TeamFL1 TeamFL1 is offline
Re: cam timing
How much is the dyno testing going to cost???
