Old 09-28-2004, 10:50 PM
JaggedFel JaggedFel is offline
Question How do i adjust fuel/air mixture?
A few weeks ago, my 95 eclipse gs started shuddering under load in the low rpm range, and got steadily worse over the next weeks. last weekend i got sick of it and took out the plugs. the electrodes were really really white, which i assume means i was running to hot/lean. so i replaced the plugs, and it ran great for a day or two, and now i'm starting to feel the shudder come back a little, which i'm sure will get worse over the next few days. how do i fix this? is there some way to adjust the fuel/air ratio? any help whatsoever is appreciated.
-j
Old 09-29-2004, 04:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: How do i adjust fuel/air mixture?
Rather than adjust the AFR, figure out what shit the bed and caused the change in the first place. On that car I wouldnt know where to start. Being to lean is usually a problem at high rpm, not low rpm. Are there any CELs?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-29-2004, 08:14 AM
what's a cel?
and what might have shit the bed?
i dont know what else to look for that might have gone bad
thanks
Old 09-29-2004, 08:34 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
CEL = Check Engine Light
DTC = Diagnostic Trouble Code
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-29-2004, 06:27 PM
nope, no check engine lights, sorry
Old 09-29-2004, 07:41 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
could be your o2 sensor ig going slightly bad, but not enough to trip a CEL... or fuel pump is gettign shitty...
Old 09-29-2004, 09:08 PM
how would i investigate a faulty o2 sensor? some sort of obd2 diagnostic software or something? is that expensive? and what about the fuel pump? how can i tell if it has shit the bed?
thanks
Old 09-29-2004, 09:41 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
95gs isnt obd-II compatible.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-30-2004, 08:05 AM
shit.
well does anybody know how to tell if a fuel pump is bad, or how to test an 02 sensor?
Old 09-30-2004, 08:13 AM
crap, im not sure, but someone on here should know, just give it a few someone will help you im sure. Do a google search for testing fuel pump, or 02 sensor, try to find one for a 2g
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-30-2004, 09:35 AM
AF - Advisor
If it was a fuel delivery problem it would get worse at high rpm.
To check the O2 sensor connect a scan tool or datalogger and watch the trace. If there is no CEL theres no help reading the codes. You could just replace it, but that costs money.
I'm still not convinced this is a fueling issue.
Kevin Jewer
Old 09-30-2004, 12:28 PM
yeah that's what my dad says, if it was a fuel problem it would get worse at high rpm....... but at the same time, why did it go away when i replaced my plugs? weird, right? btw, thanks a lot for all your help, af is great
Old 09-30-2004, 02:37 PM
hmmmm... possibly plug wires?
Old 09-30-2004, 06:02 PM
ok, i guess i'll look into plug wires/o2 sensor/fuel pump, and see if any of them are faulty if i can..... where do you suggest looking for these things besides ebay?
Old 09-30-2004, 07:01 PM
and hey, does anybody know how to monitor fuel pressure on my stock 95GS? Or how to monitor the o2 sensor? because if i could find where the problem originated, it would probably save a lot of diagnosis time....
