rear
how can i tell what the rear is in a 74 camaro without taking it apart.
2000 Mustang - just a V6 with lots of good looks 1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit. 1999 F-150 Lariat 4x4 5.4L "Only babies suck bottles (NOS)" |
Re: rear
you can get the rpo code off of the axle housing.. should be towards the front of the car, on the passenger side.. probably be all rusty and dirty.. need to get under there with a wire brush and flashlight
1991 Camaro Z28 |
Re: rear
i dont know about the older ones, but you can tell what ratio you have on the fourth gens by removing the cover and looking at the numbers stamped on the side of the gears...
*Better power-to-weight ratio than a C6 corvette* |
Re: rear
If your going to remove the cover you can just count up the teeth on each gear and figure out the ratio with that.
Re: rear
oh but that requires so much counting...and thinking...and math
The fast way to tell the ratio is to put a small piece of 200 MPH tape on the drive shaft and one on the tire. Get your floor jack and jack up the rear. Now rotate the drive shaft by hand. So, for example if your driveshaft turns 4 time to make your tire rotate once you have a 4 to one gear ratio. . § §§§§§§§§§§§§§§§§§§§§§§§§§§§§§ REFUSE TO LOSE § §§§§§§§§§§§§§§§§§§§§§§§§§§§§§
Re: rear
never thought of that.
Re: rear
never thought of that either, its worth a shot, thanks
Re: rear
by the rear, do you mean is its posi or open, or what gear ratio you have, or the size of the ring gear? there should be a spid label somewhere on the car, that has the build codes, they should tell you what you want to know. im afraid i dont konw where the label is or what the codes are off the top of my head, but i can try to find out for ya if you want.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
Re: rear
Ya turning the driveshaft around until the wheel goes around once will give you a rough idea of what ratio the rearend should have. Thats how I tested my rearend when I bought it.
Re: Re: rear
