Old 09-28-2004, 09:34 PM
Chevrolet Chevrolet is offline
91 Chevy Lumina stalls - DITTO
OK, I'm new at this and just read through TMSCHERR's posts on his 91 Chevy Lumina stall problems. I am in the same boat it seems, maybe worse. Also, I need to be super frugal and wise because I'm on SS income.
Here's my problem(s).
First few days - car started to stall @ lights now and then. Kept going tho in neutral. Idled fine. Service Engine light came on only once when car was still on, and for that I pulled into service station and turned off the car. When I re-started, the engine was on high rev and wouldn't come down. Restarted again, and it was OK and no more service lights have come on (except each time it stalls and they all come on).
Next few days - started also stalling sometimes going down hills or when I deceleratted.
Mechanics put on scope - nothing. checked fuel pump, changed spark plugs and wires, checked for v hose leakes; changed out 02 sensor , cleaned fuel injection system and put in a cleaner, checked (by trading out?) MAP sensor, checked TPS. Only could find car was "running rich". Wouldn't stall for the mechanics (of course not) . Sent me home.
Car ran fine that day. Next day car died once at a light, restarted fine, was running a little 'high,' but not much. THEN when I was doing 65 on a crowded freeway, I looked down to notice the motor had stopped! I pulled off, restarted the engine and gunned it to get back on the freeway but noticed the speedometer was not moving off "o", so I pulled over, stopped and started engine again. I pulled out and the car drove the next 13 miles OK to get me home. Speedometer was OK again. Only thing I noticed were slight "surges" now and then on decelerate. THAT's IT!. I'm not driving till it's fixed!
I was hoping Tmscherr would find the cause and I could piggy back off that. What a time for him to be in the process of moving. Anyway, sound like the same scenerio? Any suggestions? How do you "check out" a MAP sensor? Thanks.
Old 09-30-2004, 09:49 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 91 Chevy Lumina stalls - DITTO
I would start by changing the crank position sensor. Common problem on these cars, less that $20, and easy to change.
Old 09-30-2004, 08:52 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
To test the map sensor all you need is an ohmeter and a vacuum source. Its like a vacuum controlled resistor. High vacuum = high resistance, low vacuum = low resistance.
I would probably go with the TPS though. When mine went bad the engine ran up nearly to redline sometimes if I would so much as touch the gas pedal. The engine would also surge when I let off the gas if I was allready driving. This could also cause an intermittent stalling problem like you are experiencing.
Old 10-23-2004, 11:28 AM
Found it!
After much debate and many items tested, I decided to change out the main computer. I have been driving for a week with no stalls, so it seems to have solved the problem. Thank you for your responses. It's been a huge learning curve.
Old 10-24-2004, 10:13 PM
dwalmop dwalmop is offline
what exactly does the crank position sensor do?
Old 10-25-2004, 12:21 AM
It tells the ignition module when to tell the coil packs to spark.
Old 05-06-2012, 04:27 PM
OHara_Family OHara_Family is offline
We bought our daughter a 1991 Lumina 3.1 with 113,000 miles. It was running fine then one day it just stalled out and didn't want to start without pumping and pumping and pumping the gas peddle. I had to hold down gas and break at stop lights just to get her home about a mile. Once home she wouldn't run. She would run for a couple minutes and die which is open loop when running, closed loop is when the sensors kick and it would die. Pulled spark plugs, they were black meaning no spark. Can only be 2 things....99% of the time it's the crank sensor or the coil pack. We tried coil pack first, no go. Then the crank sensor for $13.99 at O'Reilly's Auto Parts and it took 3 times starting and turning off for the computer to read the change and now she's back up and running. Before the coil pack and crank sensor we put on a MAP sensor, MASS sensor, Fuel filter, Spark Plugs, Air filter and no luck. Hope this actually helps someone becaue we did tons of research and found suggestions but noone has put what has actually fixed their Lumina.
Old 05-06-2012, 06:14 PM
maxwedge maxwedge is offline
A990 racer
Fixed many of these with either the crank sensor or ign module, I have never had one in my shop that we did not fix for non fuel pump symptoms, the pcms were also bad on these cars. BTW, welcome to AF, but in the future start a new thread, this one is 8 years old and inactive, thanks.
