Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 09-28-2004, 06:59 PM
bluenoser13 bluenoser13 is offline
uneven braking on Jetta III
Hi:
i am a newgie to this forum. My daughter has a 1997 Jetta GL 2.0. When you step on the brakes, the car slides to the left. Her boyfriend changed the master cylinder and the hose so that it is using the front brakes. He has bleed the sytem several times and can't get the rear brake working.
Any suggestions? He disconnected the brake actuator on the rear axle.
Thanks
Bluenoser13
Old 09-29-2004, 04:10 PM
boschmann boschmann is offline
Re: uneven braking on Jetta III
If it's still pulling he should check that the caliper slide pins are working properly. What bleeding method is he using, vacuum, pressure, two-person? Try another method. Could a rear wheel cylinder be frozen?
TypeX TypeX is offline
I also have a '97 Jetta GL , although I can't say I've had that problem. My guess, however, is that the brakes themselves aren't the problem. It's probably a suspension or tyre problem; out of balance or the suspension is shot or something like that.
Hopefully that will point you in the right direction .
Old 10-01-2004, 10:32 AM
89accordhb's Avatar
89accordhb 89accordhb is offline
Most likely the wheel bearings are bad or the rear caliper slide pins are rusted on .. if it has the disks in the back.
Try a pressure bleeder to ensure all air is out of the system.
95 VW Jetta VR6
89 Toyota Camry
89 Honda Accord HB
www.hypnopadiaproductions.com/car
Old 10-02-2004, 05:34 PM
dj smurf dj smurf is offline
try the height sensing poportioning valve which controls the fluid wich flows enely through the braking system
