Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 09-28-2004, 06:24 PM
gavinbr gavinbr is offline
sunfire 2.4gt trouble code #P0172-system rich
hello,
has anybody had problems with the 2.4 GT running to rich [trouble code P0172] or chugging/loping at idle. runs good otherwise
any suggestions or experiences welcomed
thanks
gavinbr
Old 10-08-2004, 02:03 AM
LD9Grandam LD9Grandam is offline
Banned
Send a message via AIM to LD9Grandam
Re: sunfire 2.4gt trouble code #P0172-system rich
might be your IAC, or some type of vacum leak. Try taking off the IAC and spray it down with carb cleaner.
Old 10-08-2004, 03:52 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Ld that the IAC is a good place to start.
Old 10-11-2004, 02:35 PM
code 0172
hello,
thanks for your input
however i have changed the following items
1] gas filter
2] manifold absolute pressure sensor[controls fuel delivery], tested out of specs
3] intake air temp sensor[controls air/fuel ratio], tested out of specs
4] front exhaust manifold sensor
5] engine temp switch[air fuel/ratio]
6] cleaned IAC seems OK, havn't tested its resistance though
7] checked EGR appears OK
next on the list are...........
1] 2nd oxygen sensor
2] Idle air control sensor[IAC]
3] throttle position sensor [IAC]
4] fuel pressure regulator
what else could it be?
vacuum checks oK!
gavinbr
PS: if anybody uses the chilton manual their are some errors in it, the wiring diagrams are general not shown for specific year, the oxygen sensor diagram shown is incorrect and i'm sure there are some others?
for those who donot have an OBDII testor and want to delete codes
just remove the PCM 10amp fuse in the engine compartment fuse box. this is hot all the time and controls the computer memory.
Old 11-05-2004, 08:07 AM
avery3b avery3b is offline
Post Mine doing it too
HELP!!!!! Just bought car. While idling car seems to want to stall/no engine light on. Was fine while driving. Yesterday we just did tune up and now engine light is on. Did you find out what was wrong with yours? Just put all my money into buying it.......
