Old 09-28-2004, 04:55 PM
ChrisinNH ChrisinNH is offline
Send a message via AIM to ChrisinNH Send a message via Yahoo to ChrisinNH
Changing the tire size might screw up the computer on my '98 S-10?
Hello, I am posting to hopefully find out if switching tire sizes is going to screw up the computer on my '98 S-10. I was told that going from the current 205-75-15 tires to any 14" would but how about staying in the 15" size, but going to 235-75-15. These actually come off of a '91 Blazer I believe. Think the Rims from a '91 Blazer will fit properly on my '98 S-10 and if they do, will the slightly bigger tires cause problems with the computer in the S-10?
Okay, any input is greatly appreciated.
ChrisinNH
Old 09-28-2004, 09:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Changing the tire size might screw up the computer on my '98 S-10?
You can go into the truck's computer and change the tire diameter.
Go here to figure the differences between the two:
http://miata.net/garage/tirecalc.html
Old 09-28-2004, 11:28 PM
I guess it's not so much the speedo that I am concerned with but the ABS system and the lights on the dashboard coming on because of a malfunction because the tire size has changed. Assuming that this size tire will fit fine without rubbing. And hopefully the Blazer Rims will fit fine as well. That's the real concern though is that the rims fit right and that the computer doesn't wig out and the ABS stop working properly...the speedo can be off a bit, that won't bother me much.
ChrisinNH
Old 09-29-2004, 12:26 AM
BlazerLT's Avatar
AF -Advisor
No, it won't do anything like that.
But it will screw up your Speedo measurement and your odometer.
