Old 09-28-2004, 04:55 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
hydraulic clutch HELP?
i have a 93 2.8L s-10 that the cluch will dissingage for about the first 5 mins of use and after that it wont dissengage enough to shift. i was wondering if this is a common problem and how to fix it. right now im trying to take off the master cluch cilinder. im having trouble disconnecting the lower hose. i could use the help. thanks
Old 09-28-2004, 05:21 PM
hotwheelsgt's Avatar
hotwheelsgt hotwheelsgt is offline
Send a message via MSN to hotwheelsgt Send a message via Yahoo to hotwheelsgt
Re: hydraulic clutch HELP?
did you bleed it real good?
Old 09-28-2004, 09:48 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Check if the clutch fluid is low.
The clutch fluid resovoir is near the brake booster on the driver's side portion of the firewall.
Old 09-28-2004, 10:03 PM
Mikado14 Mikado14 is offline
First, check to see if there is fluid leaking from the slave cylinder. If it is, change it out and bleed it.
If it is not, then the problem lies in the clutch master cylinder.
Since you stated that you are trying to remove the master cylinder, I will assume that you have already checked this.
Been a while, but if I remember correctly, there should be a steel line running from the master down the side of the frame. There is a hose that connects the steel line to the slave. The swivel on the hose is at the steel line. You will have to remove it there. The hose will come out with the slave.
Old 09-28-2004, 10:06 PM
BlazerLT's Avatar
AF -Advisor
True, but before you start ripping out parts how about just checking the fluid level.
Old 09-29-2004, 09:48 AM
yeah i already have checked the fluid level and it is full and it does not seem to be leaking from anywhere i think its the upper slave cilinder or whatever its called but im going to remove them both because i cant figure out how to disconnec them from eachother. im picking up a hainsor chilton today for some addes help. thanks for the input
Old 09-29-2004, 12:24 PM
BlazerLT's Avatar
AF -Advisor
Ah, ok, it's often the small things that are overlooked.
Just making sure.
Old 10-01-2004, 07:37 PM
Hbear1027 Hbear1027 is offline
when you take off the clutch mster clyder just unbolt it.. let it drop and then undo the lines is a 13mm or a 14mm...
