Old 09-28-2004, 04:53 PM
siouxlady2001 siouxlady2001 is offline
engine hum through radio
Have had engine hum through radio for some time. Had mechanic look at it and replaced radio with after market. No luck. Doesn't do it all the time. Putting up window (power), turning on lights or pulling up on emergency brake helps and/or stops noise. help!!! Its driving me crazy!
Car is a 94 Gt with a 5.0.
Old 09-28-2004, 06:05 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Re: engine hum through radio
stock radio? got an amp in the trunk? sounds like bad wiring, look for help at http://www.crutchfield.com/S-wsYWapP...n=engine+noise
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 09-28-2004, 10:20 PM
brentmcq brentmcq is offline
that can be annoying. Does the feedback go up and down with the RPM's of the engine? There are filters you can buy to suppress the noise assuming the wiring is okay. Also if your spark plug wires are old and wore out you might try replacing them with some good suppression wires as plug wires can cause this problem.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 09-29-2004, 02:51 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Change your grounding point on the head unit. That will normally fix it.
Like Dan asked, do you have an amp?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-29-2004, 08:25 AM
Had the Mach 460 system in the car, thought the CD player was the
problem, has amp built into it. Replace radio, now has built in CD player and no amp but old CD player is still in dash filling hole.
Old 09-29-2004, 10:31 AM
Mendari Mendari is offline
I agree with SkylineUSA, humming is due to poor electrical grounding.
Don't spend money on any other solution until this is fixed.
Old 09-29-2004, 04:28 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i'm not all that up on stereos, but i know that if you dont' buy premium feed wire for a good system it'll cause that. also, if the wires feeding the amp are bad it'll the same thing.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
