Old 09-28-2004, 02:53 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
still electrical problems
well i replaced the fuseabole link on my mustang and the old one was wrecked so it needed replacing, but my problem now is that when i connect the battey it starts to drain it and when i turn the key nothing works. but also my little bros. broke my daily driver so im working on that all day ( shity chevys) but i would appresheate help.
Old 09-28-2004, 06:02 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Re: still electrical problems
check your grounds first and formost, then double check your installation on the alternator - that is where the problem originated from right?
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 09-29-2004, 10:47 AM
yeah it did originate from fixing the alternator
Old 09-29-2004, 04:26 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
check amperage through your alternator's charging wires, make sure they're not fried. as far as the nothing happens thing goes, it's either grounds or yet another link that's gone bad. also, if you get a short/unwanted ground in your charging circuit (alternator) it'll fry that link every time you try to fix it.
what alternator did you get? i got a 3G alternator (150 amps!) and a 4ga. charging wire from PA performance, and i've had no charging or shorting problems whatsoever.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 09-29-2004, 10:49 PM
thanks for the help ill check that out tomarrow. and i did not replace my alternator i just was checkingif the brushes and such where in good working order cause my car was not charging at an idle. everything seemed to be in good shape but im not that great with electrical stuff.
