Old 09-28-2004, 02:37 PM
kmerian kmerian is offline
Send a message via Yahoo to kmerian
a different overheating problem
My overheating problem appears to be a little different. My 89 Jeep 4.0 will only overheat at idle for about 10 minutes. Driving down the road, its fine. I have noticed that my electric fan is not kicking on. Also, when it overheats, the resevoir will be full to the top with hot coolant. It only leaked once, and that was because the cap was loose. Any ideas?
Old 09-28-2004, 08:31 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: a different overheating problem
You answered your own question. Fix your fan. Its either the relay, sender switch, wiring or the fan itself.
Old 09-28-2004, 11:01 PM
Saudade's Avatar
Saudade Saudade is offline
Yep. At idle there's not enough air or coolant flowing through the radiator. My fan kicks in all the time if I idle long enough.
Do you have A/C? If so, does the fan kick on when you turn the A/C on?
Old 09-29-2004, 09:58 AM
Nope, it doesn't kick on at all, is there a test I can do to see if I just need to replace the fan, or the relay or the switch? Or should I just replace all three?
Old 09-29-2004, 01:31 PM
Saudade's Avatar
There's a few things you can do.
Disconnect the fan from the harness and run some jumpers from a 12 volt source (the battery or a battery charger) to the fan and see it it works.
Connect a voltmeter to the harness end of the connection and see it you get any voltage with the A/C on.
You can also disconnect the connector for the temperature switch (on the radiator) and simply put a jumper across both terminals on the harness side. This should also send voltage to the fan connector.
Old 10-01-2004, 12:43 AM
aviat aviat is offline
I have the same problem, haven't fixed it yet. I find that if (not moving)I am idling, I get very hot. If I rev it up, I can watch it cool down. I think (besides the fact that my elect fan is not turning on to help)that my clutch for my mechanical fan is not tight enough at idle to have the fan spin enough.
Old 10-01-2004, 12:54 AM
Yow_wee Yow_wee is offline
Send a message via Yahoo to Yow_wee
after you figure out what is wrong with the fan and get that working (hopefully this is your problem) you should go to ebay and search for "cherokee cooling mod" You will find someone selling a small kit that allows you to run the fan manually by a switch in the cab or let it come on as usuall. It comes with factory type plugs that fit into (between) factory harness plugs.
Old 10-01-2004, 07:08 AM
gtmud gtmud is offline
It sounds like you have 2 problems. First, I would replace your mechanical fan clutch, when it heats up, engine off does the Mech. fan turn easy? If so its toast. Saudade told you else to do. Godd luck.
Old 10-02-2004, 01:33 PM
Saudade's Avatar
Make sure you coolant level is correct when the car is cold. Yours (and my '88) uses a closed system with a pressurized return bottle. If there's any air trapped, you'll never get enough coolant in the radiator to get the electric fan to turn on. It's tough to purge the air out. There are many threads already in here with advice and even conversions to an open system.
Old 10-05-2004, 11:40 AM
Re: Re: a different overheating problem
Tried that, the fan is difficult to move when the engine is hot, so I guess it is the electrical fan.
