Old 09-28-2004, 01:35 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Smoother Ride
I have a totally stock suspension. What could i do to smooth out my ride? (other than getting better tires and using a softer psi) I heard about aftermarket shocks, etc, but i'm clueless as far as suspension goes. Handling doesn't really concern me, since i'm not going to race the thing, just want a ride that doesn't jolt everytime u hit a bump in the road
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 09-28-2004, 02:41 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
Re: Smoother Ride
get kyb gr2's. i hear they soften the ride in rough places, and they arent expensive either.
Old 09-28-2004, 02:47 PM
icE_x's Avatar
Re: Smoother Ride
yummy i'll look it up. I could live with the stock suspension, but i think something a little nicer will make for a better ride
K, found a site that sells em:
http://www.prostreetonline.com/buy/k..._shocks/honda/
However, you can see that they have 2 sets for 1990. They have one that says 89-91 and one that says 90-97. I'm guessing go with the 89-91? And how much would a shop charge to put em on? Or is it easy enough to do yourself (if ur a newbie like me, lol)
Old 09-28-2004, 03:13 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
shocks
all you really have to do is jack each wheel up ,take off the springs/shocks...3 bolts under the hood & I think 1 or 2 bolts behind the wheel,its not hard at all to take one off,but you may need a breaker bar for the bottom bolts,same goes for every wheel,
then take it to your nearest shop that would change them for you,its like 8 bucks a spring to change,so it shouldnt be too much,
evans big O tires,maybe wal-mart,any shop that oil changes/tune ups../mufflers.....just call around,you'll find one cheap,
but it is recommended that you probably wanna take the shocks/springs off yourself,because they'll probly charge alot,then say somthings broke & you need to replace it & take all your money,
try to see if you can get somone to help you,
good lucc
In the process of B00stin my D
Old 09-28-2004, 03:35 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: Smoother Ride
Some places will loan out a spring compressor, which you will need to get your stock springs out. It's not hard, it only took me an hour when I put my coil-overs on. Pretty much same process as changing the shock itself.
Old 09-28-2004, 04:09 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Smoother Ride
you dont have to have a spring compressor, it just makes things safer. Its a simple bolt on nothing to it job, should take around 2 hours.
Old 09-28-2004, 04:10 PM
Forunn Daberator
Re: Smoother Ride
also check all your bushings, if there dry wrotted then that would contribute to a ruff ride.
