Old 09-28-2004, 12:02 PM
undrcroft undrcroft is offline
valve cover gasket set question.
ok, got oil on the spark plugs so i'm replacing the spkplug tube gaskets, but the kit came with these other rings the same size but round instead of flat. not talking about the bolt washers. just 4 little rubber rings the size of the spkplug tube gaskets, where do these go?
Old 04-14-2009, 07:07 AM
jshort74 jshort74 is offline
Re: valve cover gasket set question.
Those probably are for the base of the tubes. Don't ask me how to get the tubes off to replace them though? Oh yes, I couldn't get the grommets on the valve cover bolts either.
Old 04-14-2009, 02:49 PM
mpumas mpumas is offline
The reason you get oil in the spark plug tubes are leaking gaskets. The ones that attach to the valve cover are the flat ones and they usually fix the problem but not always. There are also gaskets under the cam caps that can leak and the fix is to use the other gaskets you talked about. If you decide to replace the lower gaskets make sure the engine is cold and after replacing adjust the valves.
Old 04-15-2009, 02:23 PM
somick's Avatar
somick somick is offline
Do you realize that you replied to a thread that is almost 5 years old?
Originally Posted by RIP
Please post back when you fix it so we all will learn something
