Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-28-2004, 10:42 AM
OOCHIEF OOCHIEF is offline
Question Make truck run cooler
I recently replaced the factory exhaust with a Gibson super truck exhaust and replaced the factory air filter with a K&N filter. The truck has more overall power but runs hotter. I want to know if anyone knows what else i can do to my truck to make it run cooler. Please reply. Thanks!
Old 09-29-2004, 08:49 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Make truck run cooler
the easiest things to do would be to check the coolant/water ratio, make sure that the radiator isn't obstructed(bugs, leaves, and that kind of stuff on it). you could also change your T-stat to a 180* (stock one is around 195* I think)
also may want to check the fan clutch and water pump to make sure they are working properly.
hope this helps some,
Keith
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
