Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 09-28-2004, 08:10 AM
mn3 mn3 is offline
2000 Durango Infinity wiring diagram?
Hello:
I have 2000 Dodge Durango with a factory infinity (CD & cassette) head unit. I recently replaced the head unit with an after market head unit (Alpine) with a beefy internal amp. I am tryin to find information about the stock infinity amp and wiring info. Not sure if I shoudl bypass the amp and use the Alpine internal amp or not.
Anyone that know where I can get a wiring diagram for the 2000 Durango Infinity system, please let me know.
Thanks,
Mn3
Old 10-05-2004, 09:12 AM
fastcompany166 fastcompany166 is offline
Re: 2000 Durango Infinity wiring diagram?
I'd probably just Google "2000 Durango Infinity Wiring" and see what comes up. I also have a 2000 SLT, and I'm looking for replacement front (low end) speakers. Did you go with aftermarket speakers as well? On the amp issue, I would recommend going with a branded amp to match up with your new head unit. Rockford, Alpine, PPI, they're all much superior to the OEM Infinity amp. While it's not a bad amp, the performance you will realize from an aftermarket model will be far greater. Good luck.
Old 10-05-2004, 08:33 PM
mn3 mn3 is offline
Re: Re: 2000 Durango Infinity wiring diagram?
I kept the facotry infinity amp and speakers. I did not realize my truck had the infinity amp until I hooked everythign up. I have not had time or found details to do any more. The sound sounds fine but I wonder what it would sound like with the amp from the head unit.
Mn3
Old 10-06-2004, 02:22 PM
If you would like to part with your factory speakers, I could be interested. I really only need the low-end front 6.5" speakers, but if you don't want to break up the system, let me know and decide on a price. FYI, I'm in the Dallas/Fort Worth, Texas area.
Old 10-28-2004, 04:50 AM
dmburrows dmburrows is offline
If you have the infinity system with the 2 tweeters on door, you can get an almost exact match from Walmart ($10 i think). They are just dual cone - not coax.
Old 10-28-2004, 07:58 AM
That is the system I have, and I am going to go with aftermarket drivers. Dodge wants $78 EACH for the factory replacements, so a 6.5" bass-mid driver would work ok. I just want to try to match up the crossover point as close as possible to keep the system relatively matched. Thanks for the idea.
