Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-28-2004, 06:00 AM
YuriyM YuriyM is offline
1990 Camry 4 cylinder .Need advise
Just years ago my car 140Kkm had't problem with air care.But my car was stolen.It was found after 3 days.Some scathes... nothing look serious.After getting my car from body shop,I found that the car had ingine vibration and lost power.Mechanic changed wares, distributor, fas filter, sparks and I paid for it. And car seemed to work fine until next air care. All air car pointes were too high.I checked the timing angle.It was abou 15 degrees ahead.When I adjust it as it is supposed to be, the car have a ingine vibration and lost power again.If anyone have any idea,what's happened whith my car when it had been stolen?
Old 11-16-2004, 07:56 PM
cptwingnut cptwingnut is offline
Re: 1990 Camry 4 cylinder .Need advise
when you checked the timing, did you put the engine in limp home mode, otherwise, you adjust the timing after the ecu modifies the timing, I believe your oem preset is 10 BTDC, and what is air care? do you mean the air filter?
good luck man
