Old 09-28-2004, 02:34 AM
anonymous_1 anonymous_1 is offline
Send a message via AIM to anonymous_1
tempature guage
my temp guage doesnt work my fan does tho is it just a plug or something that needs to be plugged in or what
Old 09-28-2004, 10:03 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: tempature guage
I had the same problem when I 1st got my car,I had someone look at it & he pluged it in,it started working,
its a plug below the distributor,on top of the transmission,
you might wanna check around that area for plugs thats unplugged!
if everythings plugged up,you might wanna check behind your gauge cluster to make shore its plugged in,
In the process of B00stin my D
Old 09-28-2004, 10:11 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: tempature guage
theres a temp sensor, I'm clueless as to where its at but I bet you can find it in:
http://www.binghamtonlife.com/manual/2gsm/default.htm
If everything is plugged in and you replace the temp sensor and its still now working you may have a bad gauge. On old stuff you could take out the cluster and trade down the leads that go to the temp sensor and hook one to the battery and ground out the other and if it worked the hand would start rising (remove power quickly or you'll burn up the guage). But like I said that was on old 70's stuff dont know if it would work on yours.
Old 09-29-2004, 11:55 AM
Re: Re: tempature guage
the temp sensors,behind the head,under the throttle body,
theres 2 plugs,the oil pressure plug & the temp sensor,its the BIG one,reach back there & fell if you have a wire from the harness.hanging,
